How to save the changes you made?
You will probably make some changes you'll want to save.
As we mentioned in the previous chapter, you'll have to click on the left encoder to enter the save menu.
Once you're in the save menu, you'll rotate the left encoder to select the slot you want to save or load from. Once you have found it, click the left encoder to confirm the selection.
Synthia has four slots available for saving your tracks and sounds, and you'll have to choose which one you want to save the track to.
While doing this, the LED matrix will look like this:
Now choose the desired action - load or save.
And confirm or cancel your selection.
To exit the save menu, simply press any of the buttons, rotate or click the right encoder, or move one of the two sliders.
