Restore Spencer's firmware
Once you're done coding and just want your Spencer to be "normal" again, you need to restore his base firmware.
This is quite simple, just connect your Spencer to the USB port of your computer and press the "Restore firmware" button on the top right.
You will be prompted with a window where you need to choose the device that you are restoring the firmware for.
Choose Spencer, of course.
Wait for a few seconds, and your Spencer will be back and running like usual.
You need to do this whenever you're done coding your Spencer if you want him to revert to his initial out-of-the-box functionality.
