Armstrong Anatomy Guide
This will be a helpful guide where you’ll learn more about the different components of your new DIY robot arm - Armstrong.
1. Circuit boards
The black boards you've gotten in your kit are called circuit boards.
Professionals call them printed circuit boards or PCBs.
What does it do?
  • It holds all the electronic components in place.
  • It provides electrical connections between the electronic components.
If a material is conductive, it conducts electricity; electrical charge can flow through that material easily.
Where are PCBs used?
They’re used everywhere!
Did you know?
PCBs were invented by Paul Eisler.
He invented it in the 1930s, but the predecessors of modern-day PCBs have been around since the age of gramophones and vacuum tube radios, just in a somewhat different form.
2. ESP-32
That part is called a microcontroller, and it runs everything. If the PCB was a body, this part would be the brain.
One of the key features of the ESP-32 is its integrated WiFi and Bluetooth capabilities, which make it an ideal platform for building IoT devices.
3. Pushbuttons
The pushbuttons can be pressed to activate specific commands on your device.
When you push on them, they complete the circuit and allow electricity to flow through, which can trigger an action.
You can find this 6mm THT pushbutton on Armstorngs’ Brain board:
4. FPC/FFC Connector
A Flexible Printed Circuit (FPC) connector, also known as a Flexible Flat Cable (FFC) connector, is an electrical connector used to connect flexible printed circuitry (FPC) or flat flexible cables (FFC) to other electronic components or circuit boards.
These connectors are designed for applications where space is limited or where flexibility and low-profile connections are required.
5. Servo motors
Servo motors are a type of rotary actuator widely used in various applications, including robotics, automation, and control systems.
They work based on a closed-loop control system, aiming to maintain a precise position or angle of the motor's output shaft.
They operate by receiving a control signal, comparing the desired position with the actual position using feedback, and making continuous adjustments to the motor's operation to achieve and maintain precise control over its position or angle.
This makes them ideal for applications requiring accurate and controlled motion.
The ones used on Armstrong are called MG90S, and this is what they look like:
6. Encoders
Encoders are devices used in various applications to convert mechanical motion into electrical signals or digital data.
They provide information about the position, speed, or direction of a rotating shaft or object. There are two primary types of encoders:
1. Rotary Encoders: These are used to measure the angular position of a rotating shaft. They generate electrical signals or digital pulses in response to shaft rotation, allowing precise tracking of position changes.
2. Linear Encoders: These are designed to measure linear motion along a straight path. They are commonly used in machinery and equipment to provide accurate feedback on the position of components such as machine tool slides or conveyor belts.
Encoders play a crucial role in various industries, including manufacturing, robotics, automation, and control systems, where precise and real-time feedback on position or motion is essential for accurate operation and control.
This is what the Rotary Encoders on Armstrong look like:
7. LEDs
These electronic components will light up on your Armstrong.
LEDs convert electrical energy into visible light.
Watch out - LEDs are polarized!
Because of this, you need to pay attention to how you are going to place your LED in the electronic circuit.
They mark polarity!
The positive leg is longer (we call this one the anode), and the shorter leg is negative (we call this one the cathode).
Electrical energy flows from the anode to the cathode, not in the opposite direction.
Historical fun facts:
A Russian inventor Oleg Vladimirovich Losev made the first LED in 1927.
Did you know?
LED lightbulbs are the most efficient type of lightbulbs.
Unlike “regular” “old” bulbs (we call these incandescent lightbulbs), which release 90% of their energy as heat, LEDs use energy far more efficiently with very little wasted heat.
There are also some smaller components on Armstrong, like:
1. Resistors
Resistance
Resistors have a property of resistance - they lower the amount of electrical energy flowing through the circuit.
You could say that they “resist” the flow of electrical energy.
The unit of resistance is called Ohm and it was named after a German physicist, Georg Simon Ohm.
2. Capacitors
It can absorb energy from a circuit and store it temporarily.
Later on, this stored energy can be released back into the electronic circuit.
Capacitance
We call this property - capacitance.
The unit of capacitance is called Farad (we use the letter F as short for Farads).
This unit was named after an English physicist, Michael Faraday.
Capacitors were discovered by Pieter van Musschenbroek a looong time ago - in 1746.
This is an electronic symbol for a capacitor:
3. Color sensor
Color sensors are electronic devices designed to detect and measure the color of objects or surfaces.
These sensors work by analyzing the wavelengths of light reflected or emitted by the object and providing information about its color.
Color sensors are commonly used in various applications, including industrial automation, color detection in manufacturing, etc.
This is what the one on Armstrong looks like:
