Armstrong Arduino Installation And Setup
Welcome to the Armstrong Arduino setup guide!
We'll use Arduino IDE to teach you how to upload code to your Armstrong, so let's get started.
Installation
After you download and install Arduino IDE, you should install the Armstrong board.
Here's how to do that:
- Open the Arduino IDE
- Select "None" under Compiler warnings and add the following URL under Additional board Manager:https://raw.githubusercontent.com/CircuitMess/Arduino-Packages/master/package_circuitmess.com_esp32_index.json
Then go to Tools -> Board -> Circuimess ESP32 Boards, and select Armstrong from the dropdown menu.
