Electronics 101
1. Circuit board
The black head-shaped thingy you've gotten in your kit is called a circuit board.
What does it do?
Where are PCBs used?
They’re used everywhere!
Did you know?
2. Resistors
We call these legs "component leads".
Resistance
This is Georg Simon Ohm:
3. Switch
Historical fun fact:
4. Capacitor
This is an electronic symbol of a capacitor:
A capacitor can absorb energy from a circuit and store it temporarily.
We call this property - capacitance.
The unit of capacitance is called Farad (we use the letter F as a short for Farads).
This unit was named after physicist Michael Faraday.
Historical fun facts:
Capacitors were discovered by Pieter van Musschenbroek a looong time ago - in 1746.
5. Transistor
The transistor is an electronic component that can be used as part of an amplifier or as a switch.
It is made of semiconductor material.
Transistors have 3 terminals: the emitter, the collector, and the base. When the emitter is connected to the negative terminal of the battery and the collector to the positive terminal, no electricity will flow in the circuit. This is what a transistor looks like:
6. Red LEDs
