Explore the board!
This will be a helpful guide where you’ll learn a bit more about the different components of your new DIY gaming console - Bit.
1. Circuit board
The red board you've gotten in your kit is called a circuit board.
What does it do?
  • It holds all the electronic components in place.
  • It provides electrical connections between the electronic components.
If a material is conductive, it conducts electricity; electrical charge can flow through that material easily.
Where are PCBs used?
They’re used everywhere!
Did you know?
2. ESP-32
That part is called a microcontroller, and it runs everything. If the PCB was a body, this part would be the brain.
One of the key features of the ESP-32 is its integrated WiFi and Bluetooth capabilities, which make it an ideal platform for building IoT devices.
3. Display
Bit uses the TFT 1.44 display, which has a resolution of 128×128 px and 18-bit color.
Pixel is the smallest addressable element on the screen. Everything you can see on your display is made out of pixels.
Thanks to this display, you are able to play all these amazing games!
4. Edge Connector
If you have any of our Wacky robots, you can use this connector to pair them with Bit and gain access to cool new games on your device!
5. On-off switch
The switch helps you turn the device on and off. You can easily do so with one simple push.
Switches are used in almost every electronic device. They can be found on your mobile phone, computer, air conditioner, etc.
6. Pushbuttons
Just like the on-off switch, it completes a circuit and allows electricity to flow through, which can trigger an action.
However, unlike the on-off switch that can be turned on or off and remain in that position, the pushbuttons need to be pressed each time to activate a specific command on your device.
There are 7 pushbuttons on Bit and each one is used for different commands.
7. Reset button
The reset button can be used to restart your console at any time by simply clicking it.
8. USB-C connector
This connector at the bottom of the board is used to connect Bit to the computer.
Once you connect it to your PC, you’ll be able to program it in CircuitBlocks - a graphical programming interface that helps beginners get into embedded programming.
9. JST2.0 Connector
This connector is used to manually connect the battery to the PCB.
There are also some smaller components on Bit, like:
1. Resistors
Resistance
You could say that they “resist” the flow of electrical energy.
The unit of resistance is called Ohm and it was named after a German physicist, Georg Simon Ohm.
Resistors are used for tasks such as adjusting the flow of electricity through an electronic circuit.
2. Capacitors
It can absorb energy from a circuit and store it temporarily.
Capacitance
We call this property - capacitance.
The unit of capacitance is called Farad (we use the letter F as short for Farads).
This unit was named after an English physicist, Michael Faraday.
Historical fun facts:
Capacitors were discovered by Pieter van Musschenbroek a looong time ago - in 1746.
This is an electronic symbol for a capacitor:
