Electronics 101
1. Circuit board
The purple thingy you've gotten in your kit is called a circuit board.
What does it do?
  1. It holds all the electronic components in place.
  2. It provides electrical connections between the electronic components.Because of the circuit board, all electronic components can work together as a team.
    Circuit boards are usually made out of fiberglass-reinforced epoxy-laminated sheets
    Where are PCBs used?
    They’re used everywhere! In your phone, in your laptop, in your refrigerator, air conditioner. Basically, every electronic device you use has a unique printed circuit board that makes it work.
    Did you know?
    A PCB is one of the most important inventions of the last 100 years.Space travel wouldn’t be possible without them.
2. Resistors
They fall in the category of passive electronic components. Passive electronic components do not generate electrical power and do not need electrical power to work.
They just modify the flow of electrical energy in their own unique way. Resistors that you have gotten in your package have a cylindrical shape and two tiny metal legs.
We call these legs “component leads”.
Resistance
Resistors have a property of resistance - they lower the amount of electrical energy flowing through the circuit. They “resist” the flow of electrical energy.The unit of resistance is called ohm and it was named after German physicist Georg Simon Ohm.
This is Georg Simon Ohm:
3. 3V coin cell battery
You will see the number of volts written on almost every battery as it’s one of the most important pieces of information about the battery.
For example, a mobile phone has a battery of 3.7 volts, and a car has a battery with the voltage of 12 volts.
Useful tip:This particular battery size and model is called a CR2032 coin cell battery.
4. Battery holder
This battery holder is a plastic electronic component with two metal springy legs.
It is used for holding the coin cell battery in place and connecting it with the rest of the electronic circuit.
5. Switch
Historical fun fact:
6. 3mm RGB LEDs with built-in color changing chip
The best part of BOB is the RGB LEDs that will give him a unique look - once you turn him on, he will light in different colors.
What do LEDs do?
LED stands for light-emitting diodes.LEDs convert electrical energy into visible light.This is an electronic symbol for a light-emitting diode:
RGB in the name stands for Red, Green, and Blue.
This means that these particular light-emitting diodes can light up in three different colors.
These LEDs are very special because they have a tiny built-in color-changing chip. Look closely into an LED and you’ll see a black dot - the chip that controls the colors.
Please, make sure to put the LEDs in the circuit board properly!
Watch out - LEDs are polarized!
Light-emitting diodes (LEDs) are polarized.
Because of this, you need to pay attention to how you are going to place your
LED in the electronic circuit.
They mark polarity!
Oh no! The coin cell battery supplied with your BOB is too much for the poor little LEDs”.
But don't worry, we sent resistors to the rescue!
Historical fun facts:A Russian inventor Oleg Vladimirovich Losev made the first LED in 1927.
Did you know?
LED lightbulbs are the most efficient type of lightbulbs.Unlike “regular” “old” bulbs (we call these incandescent lightbulbs), which release 90% of their energy as heat, LEDs use energy far more efficiently with very little wasted heat.
