Explore the components!
Electronics 101
1. Circuit board
The purple head-shaped thingy you've gotten in your kit is called a circuit board.
What does it do?
Where are PCBs used?
They’re used everywhere!
Did you know?
2. Speaker
You want to be able to hear the music coming from Buttons, and that would not be possible without this speaker.
3. Headphone jack
This is a headphone jack for standard headphones/earphones. Sorry - no wireless headphones here!
Once you start making music on your Buttons, you can plug in the headphones, and the sound will automatically transfer from the speakers to the headphones.
4. The 555 Timer IC
This component is used in a variety of applications from timing and oscillation circuits to pulse generation and control systems.
One of the key features of the 555 timer IC is its ability to generate precise and stable time delays.
5. Resistors
These resistors don't look like the ones you saw on our previous Wacky Robots.
Resistors are the little dots above the pushbuttons.
They are linked to the pushbuttons and the oscillator. Because each resistor has a different resistance, pressing each button produces a different sound.
