Chatter Arduino Uploading Code
After setting everything up, we can move on to uploading code to your Chatter.
Choose what to upload
[@portabletext/react] Unknown block type "code", specify a component for it in the `components.types` prop
Let's make sure your Chatter is ready for the upload!
Turn on your Chatter and plug it into your computer with a USB cable.
Next, in Arduino go to Tools -> Port, and select the port your Chatter is connected to. It’s usually the only option available.
And that's it! You have now uploaded your code to the Chatter. Great job!
