Open your CircuitPet box and check if you have all the components. Make sure to lay it all on a clean surface where you'll inspect if everything is there according to the photo and the list below.
In case something is missing, please contact us at contact@circuitmess.com.
Send us a photo of everything that came in the box, and we'll get back to you as soon as possible to resolve the issue.
Here's the list of components: 1. Stickers 2. Yellow lanyard 3. Collector's card 4. Li-Po battery 5. Acrylic stand 6. Display board 7. Main circuit board 8. Back acrylic casing 9. Front acrylic casing 10. RGB LED 11. Resistors 12. USB-C cable 13. On-off switch 14. Male and female pin headers 15. Pushbuttons 16. Button caps 17. Metal bolts 18. Brass spacers
