Explore the board!
1. Circuit board
The blue square-shaped thingy you've gotten in your kit is called a circuit board.
What does it do?
Where are PCBs used?
They’re used everywhere!
Did you know?
2. ESP-WROOM-32
This microcontroller runs everything, and you could say that this is Clockstar's brain. ESP-WROOM-32 is a powerful module mainly used for sound encoding and streaming music. It is reasonably priced considering all its abilities.
Apart from being famous for sound encoding, ESP-WROOM-32 also controls button, display, gyroscope, and everything else.
Due to its complexity and sensitivity, this module is already connected to Clockstar's main board.
- ESP-WROOM-32 data sheet
3. USB-C connector
This connector is used to connect Clockstar to the computer and charge its battery. Once you connect it to your PC, you’ll be able to program it in CircuitBlocks - a graphical programming interface that helps newbies get into embedded programming.
4. Buzzer
A buzzer is an audio signaling device, which may be mechanical, electromechanical, or piezoelectric.
The main function of the buzzer is to convert the signal from audio to sound; typically, they are used in alarm devices, timers, etc.
5. JST-2P connector
This connector is used for manually connecting the battery to the main board.
6. Reset button
This one’s pretty self-explanatory - the reset button is used for resetting the whole device. You can find this useful in case something gets frozen (which is hopefully never).
7. Voltage regulator
This is the regulators that keep the voltage stable.
This regulator is extremely important since not every electrical component operates at the same voltage.
8. Chip CH340C
Clockstar can communicate with your computer over USB, thanks to this little guy!
9. Gyroscope
Gyroscopes are here to help us stay on track and keep things spinning smoothly.
To put it in simple terms, they work just like the wheels on a bike that keep us from falling over when we pick up the speed.
10. Button
This button will help you navigate through your Clockstar and choose the action you want it to do!
