Codee Build Guide (English)
Welcome to the Codee build guide!
Get ready to assemble your new virtual pet step-by-step. Let‘s dive in!
Start by removing the protective foil from both sides of each of the two acrylic casings.
Once you’re done, they should be shiny and transparent.
Next, we need to connect the battery holder to the PCB.
This step ensures that Codee will be brought to life once the batteries are in place.
Take these two components:
Peel off the sticker on the screen.
Connect them as shown:
To secure the holder from shifting, secure it to the PCB like this:
Insert the screw from inside the battery holder:
Now you will need the batteries:
Place two batteries into the holder, making sure to align the polarities (+ and -) correctly. The battery holder and batteries will have clear + and - indicators.
Personalize Codee with fun stickers!
Choose any pair you like and stick them on the designated side of the casing.
Just be careful to put the sticker on the right side of the casing.
Next, attach screws and spacers to the back casing so you can connect it to the PCB. Use these parts:
Secure the casing by placing screws from the front side and fastening them with spacers on the reverse side:
Now take what will be the front casing, the PCB, and the four screws.
Align the front casing with the PCB to ensure the display is visible. Insert four screws from the outer side of the casing:
Use a screwdriver to secure them:
The front and PCB connection should look like this:
For the final assembly, connect the back side using four more screws:
>Secure them with a screwdriver:
Congratulations!
You’ve successfully assembled your Codee. It should look like this:
How to use your Codee?
Codee will constantly be in sleep mode if you are not using it, and you can press any button to turn it on.
The buttons also serve these functions:
A - navigate to the right
B - navigate to the left
C - Enter
D - Exit
We hope you had fun building your new virtual pet!
