Electronics 101
1. Circuit board
The red square-shaped thingy you've gotten in your kit is called a circuit board.
What does it do?
  • It holds all the electronic components in place.
  • It provides electrical connections between the electronic components.
Where are PCBs used?
They’re used everywhere!
Did you know?
2. Resistors
We call these legs "component leads".
Resistance
This is Georg Simon Ohm:
3. Switch
Historical fun fact:
4. Pushbuttons
A pushbutton switch is a small, sealed mechanism that completes an electric circuit when you press on it.
When a pushbutton is pressed, a small metal spring inside makes contact with two wires, allowing electrical energy to flow.
When you release your finger from the pushbutton, the spring retracts, the electrical contact is interrupted, and electrical energy won't flow through the switch.
What's the difference between a switch and a pushbutton?
Switches have an on and off state that can be switched between by pushing the switch with your finger.
A pushbutton also has two states - on and off. A pushbutton will change its state if you push it with your finger, but it will automatically retract back to its original state when you remove your finger.
5. Capacitor
This is an electronic symbol of a capacitor:
A capacitor can absorb energy from a circuit and store it temporarily.
We call this property - capacitance.
The unit of capacitance is called Farad (we use the letter F as a short for Farads).
This unit was named after physicist Michael Faraday.
Historical fun facts:
Capacitors were discovered by Pieter van Musschenbroek a looong time ago - in 1746.
6. RGB LEDs with built-in color changing chip
LEDs convert electrical energy into visible light.
RGB in the name stands for Red, Green, and Blue.
This means that these particular light-emitting diodes can light up in three different colors.
These LEDs are very special because they have a tiny built-in color-changing chip. Look closely into an LED and you’ll see a black dot - the chip that controls the colors.
Please, make sure to put the LEDs in the circuit board properly!
Watch out - LEDs are polarized!
Light-emitting diodes (LEDs) are polarized.
Because of this, you need to pay attention to how you are going to place your
LED in the electronic circuit.
They mark polarity!
7. Transistor
The transistor is an electronic component that can be used as part of an amplifier or as a switch.
It is made of semiconductor material.
Transistors have 3 terminals: the emitter, the collector, and the base. When the emitter is connected to the negative terminal of the battery and the collector to the positive terminal, no electricity will flow in the circuit.
This is what a transistor looks like:
