Explore the chips
1. Chip IS31FL3731
This chip called IS31FL3731 drives the LED lights - all 144 of them! Later, when you turn on your Jay-D and start remixing, you'll also be able to change the LED animations that are controlled by this chip.
2. Nuvoton N76E616
Nuvoton N76E616 is a real star here. This chip controls all the inputs coming from the encoders, sliders, and the rest of the buttons. It is also directly connected to the ESP-WROOM-32 microcontroller that turns all the inputs into fun outputs that bring Jay-D to life.
3. Chip CP2014
Chip CP2014 is important because it enables you to connect to the computer. It's also used as a USB-TTL converter.
4. Small chip supporting the CP2014
Thanks to this little guy, the chip CP2014 can run without resetting each time Jay-D's connected to the computer.
5. Chip TFA9882UK
This chip is Jay-D's sound amplifier. It's located right next to the ESP-WROOM-32 microcontroller and speaker connectors on top of the board.
6. & 7. Voltage regulators
There are two voltage regulators right above the chips IS31FL3731 and CP2014.
  • The big one - 3.3V
  • The smaller one - 1.8
8. Capacitors and resistors
These small components are the main parts of pretty much every electronic device in the world. They are used to control the flow of the current in a circle.
There are a few locations on the board where these components are located, mainly around the ESP-WROOM-32 module and the display.
