Mandatory tools
In this chapter, we'll explain what tools you'll need to assemble your Jay-D.
If you have your CircuitMess Tools pack in front of you, you should be all set!
In case you got the Jay-D kit without the Tools pack, this is a good time to
  1. Glasses
  2. Cutter pliers
  3. Small screwdriver
  4. Soldering tip
  5. Lead-free solder
  6. Soldering stand
  7. Sponge
  8. Soldering iron
  9. USB Cable
For Jay-D's assembly, any entry-level soldering iron will suffice.
Soldering sponge
Diagonal cutter pliers
Standard cross screwdriver
