Electronics 101
Don't worry, it won't last long, and we will try to make it fun.
1. Circuit board
The blue head-shaped thingy you've gotten in your kit is called a circuit board.Professionals call this a printed circuit board or PCB. A PCB is a laminated sandwich structure of conductive and insulating layers.
What does it do?
- It provides electrical connections between the electronic components.Because of the circuit board, all electronic components can work together as a team.
Where are PCBs used?
They’re used everywhere! In your phone, in your laptop, in your refrigerator, air conditioner. Basically, every electronic device you use has a unique printed circuit board that makes it work.
Did you know?
A PCB is one of the most important inventions of the last 100 years.Space travel wouldn’t be possible without them.
PCBs were invented by Paul Eisler.He invented it in the 1930s, but the predecessors of modern-day PCBs have been around since the age of gramophones and vacuum tube radios, just in a somewhat different form.
2. Resistors
We call these legs “component leads”.
Resistance
Resistors have a property of resistance - they lower the amount of electrical energy flowing through the circuit. They “resist” the flow of electrical energy.
Scientists and engineers have come up with different symbols for each and every electronic component. This is an electronic symbol for a resistor:
This is Georg Simon Ohm:
3. 3V coin cell battery
You will see the number of volts written on almost every battery as it’s one of the most important pieces of information about the battery.
For example, a mobile phone has a battery of 3.7 volts, and a car has a battery with a voltage of 12 volts.
Useful tip:This particular battery size and model is called a CR2032 coin cell battery.
4. Battery holder
The battery holder is not as complex as the rest of the components, but it deserves a word or two.
It's made out of plastics and has two pins that you'll have to solder in order to keep it on Marv's body.
The battery holder will be used for holding the battery and giving life to your wacky robot.
5. Switch
The switch you got in your kit is a power switch, and it helps you turn Marv on and off. You can easily do so with one simple push.
The power switch controls the flow of power to an electric device - in other words, it connects and disconnects an electrical circuit.
Historical fun fact:
6. Pushbuttons
A pushbutton switch is a small, sealed mechanism that completes an electric circuit when you press on it.
When a pushbutton is pressed, a small metal spring inside makes contact with two wires, allowing electrical energy to flow.
When you release your finger from the pushbutton, the spring retracts, the electrical contact is interrupted, and electrical energy won't flow through the
switch.
What's the difference between a switch and a pushbutton?
Switches have an on and off state that can be switched between by pushing the switch with your finger.A pushbutton also has two states - on and off. A pushbutton will change its state if you push it with your finger, but it will automatically retract back to its original state when you remove your finger.
7. Blue LEDs
These electronic components will make your MARV’s eyes light up. LED stands for light-emitting diodes.LEDs convert electrical energy into visible light.This is an electronic symbol for a light-emitting diode:
Watch out - LEDs are polarized!Light-emitting diodes (LEDs) are polarized. This means that they only allow current to flow in one direction.Because of this, you need to pay attention to how you are going to place your LED in the electronic circuit.
They mark polarity! The positive leg is longer (we call this one the anode), and the shorter one is negative (this one has a funny name - cathode).
LEDs can be damaged if they receive too much energy. Oh no! The coin cell battery supplied with your MARV is too much for the poor
little LEDs”.
But don't worry, we sent resistors to the rescue! Resistors will limit the amount of electrical energy flowing through the circuit and save your LEDs from getting damaged.
Historical fun facts:
A Russian inventor Oleg Vladimirovich Losev made the first LED in 1927.
Did you know?
LED lightbulbs are the most efficient type of lightbulbs.Unlike “regular” “old” bulbs (we call these incandescent lightbulbs), which release 90% of their energy as heat, LEDs use energy far more efficiently with very little wasted heat.
