Electronics 101
1. Circuit board
The yellow bee-shaped thingy you've gotten in your kit is called a circuit board.Professionals call this a printed circuit board or PCB.
What does it do?
- It provides electrical connections between the electronic components. Because of the circuit board, all electronic components can work together as a team.
Where are PCBs used?
They’re used everywhere!
Did you know?
A PCB is one of the most important inventions of the last 100 years. Space travel wouldn’t be possible without them.
PCBs were invented by Paul Eisler. He invented it in the 1930s, but the predecessors of modern-day PCBs have been around since the age of gramophones and vacuum tube radios, just in a somewhat different form.
2. Resistors
We call these legs "component leads".
Resistance
This is Georg Simon Ohm:
3. 3V coin cell battery
You will see the number of volts written on almost every battery as it’s one of the most important pieces of information about the battery.
For example, a mobile phone has a battery of 3.7 volts, and a car has a battery of 12 volts.
Useful tip:
This particular battery size and model is called a CR2032 coin cell battery.
4. Battery holder
This battery holder is a plastic electronic component with two springy metal legs. It is used for holding the coin cell battery in place and connecting it with the rest
of the electronic circuit.
5. Vibration motor
This component makes MR. BEE vibrate and move around.
This particular motor type has a special name - an ERM motor.
An ERM motor has an off-center load, and when it rotates, the centripetal force (a force that makes a body follow a curved path) causes the motor to move.
This motor has two wires coming out of it.
The colors of the wires (red and blue) represent the polarity of the wires: blue is negative (-), and red is positive (+).
These wires are used for connecting the motor to the power source (battery) and powering the motor.
This is an electronic symbol of a motor:
6. Switch
Historical fun fact: An electrical switch was invented in 1884 by John Henry Holmes, who used it for turning lights on and off.
