Assembly
How do I solder?
One of the things you'll do as a part of Mr. Bee's assembly process is soldering!
- Adafruit’s video tutorial featuring Collin Cunningham- A tutorial featuring Collin Cunningham, a super charismatic electronics guru.
- Adafruit’s standard soldering tutorial- A great and thorough video tutorial. An absolute must-read, even if you know how to solder. Make sure to check the “common soldering mistakes” section at the end.
- Sparkfun’s video soldering tutorial- Another well-made how-to-solder video tutorial.
- Sparkfun’s standard soldering tutorial- A detailed tutorial made by Sparkfun.
- Soldering iron gets hot! Do not touch the tip of the soldering iron!Even if the soldering iron is turned off or completely disconnected from the power source, there is still a possibility that it’s very hot and, therefore, can cause very uncomfortable pain if touched. Always keep the soldering iron facing away from your hands. If you’re finished soldering, unplug the soldering iron from the power source and leave it to cool off for at least five minutes before putting it back in your toolbox.
- Clean the soldering iron!Make sure to use the sponge often and clean your soldering iron if you wish to have an easy and simple soldering experience. Carefully hold an end of the sponge with one hand and wipe the tip of the soldering iron on the other end of the sponge to remove the extra solder. Repeat the process until the tip of the iron is nice and clean.
- Keep the soldering iron on the stand when you’re not using it!
- Know how much solder is needed!Make sure to put just enough solder. Not too much, and not too little, since both can cause your newly-made device to malfunction.
- Don’t leave any residual solder on the board!The solder should only be on the parts where the pins connect to the board.Keep the rest of the board clean!
The soldering iron is very easy to use when used properly.
Step 1 - plug it in
Please use the metal stand every time you are not using the soldering iron to make sure you don't burn the surface or the circuit board
