Electronics 101
1. Circuit board
The black robot-shaped thingy you've gotten in your kit is called a circuit board.Professionals call this a printed circuit board or PCB. A PCB is a laminated sandwich structure of conductive and insulating layers.
What does it do?
  1. It holds all the electronic components in place.
  2. It provides electrical connections between the electronic components.Because of the circuit board, all electronic components can work together as a team.
    Circuit boards are usually made out of fiberglass-reinforced epoxy-laminated sheets.These are also referred to as “FR4” sheets.The FR4 sheets are used as the insulating non-conductive material, and copper is used as a conductive material.
    Where are PCBs used?
    They’re used everywhere! In your phone, in your laptop, in your refrigerator, air conditioner. Basically, every electronic device you use has a unique printed circuit board that makes it work.
    Did you know?
    A PCB is one of the most important inventions of the last 100 years.Space travel wouldn’t be possible without them.
    PCBs were invented by Paul Eisler.He invented it in the 1930s, but the predecessors of modern-day PCBs have been around since the age of gramophones and vacuum tube radios, just in a somewhat different form.
2. Resistors
We call these legs “component leads”.
Resistance
Resistors have a property of resistance - they lower the amount of electrical energy flowing through the circuit. They “resist” the flow of electrical energy.
This is Georg Simon Ohm:
3. 3V coin cell battery
Volts are the units used to describe electrical voltage.You will see the number of volts written on almost every battery as it’s one of the most important pieces of information about the battery.
For example, a mobile phone has a battery of 3.7 volts, and a car has a battery with the voltage of 12 volts
Useful tip:This particular battery size and model is called a CR2032 coin cell battery.
4. Battery holder
This battery holder is a plastic electronic component with two metal springy legs.
It is used for holding the coin cell battery in place and connecting it with the rest of the electronic circuit.
5. Red LEDs
These electronic components will make your RESISTRON’s eyes light up.LED stands for light-emitting diodes.LEDs convert electrical energy into visible light.
Watch out - LEDs are polarized!Light-emitting diodes (LEDs) are polarized.
Because of this, you need to pay attention to how you are going to place your LED in the electronic circuit.
They mark polarity!
LEDs can be damaged if they receive too much energy.Oh no! The coin cell battery supplied with your RESISTRON is too much for the poor little LEDs.But don't worry, we sent resistors to the rescue!
Historical fun facts:A Russian inventor Oleg Vladimirovich Losev made the first LED in 1927.
Did you know?
LED lightbulbs are the most efficient type of lightbulbs.Unlike “regular” “old” bulbs (we call these incandescent lightbulbs), which release 90% of their energy as heat, LEDs use energy far more efficiently with very little wasted heat.
6. Variable resistor
A variable resistor is a resistor of which the electric resistance value can be adjusted.
They come in different shapes and sizes. The one included in your box is shaped like a knob that can be turned. By turning the knob, the resistor’s resistance will change.
You will use this one for regulating the brightness of the LEDs in REISTRON’s eyes.
