Explore the components!
1. Circuit board
The black body-shaped thingy you've gotten in your kit is called a circuit board.
What does it do?
Where are PCBs used?
They’re used everywhere!
Did you know?
2. Capacitor
This is an electronic symbol of a capacitor:
A capacitor can absorb energy from a circuit and store it temporarily.
We call this property - capacitance.
The unit of capacitance is called Farad (we use the letter F as a short for Farads).
This unit was named after physicist Michael Faraday.
Historical fun facts:
Capacitors were discovered by Pieter van Musschenbroek a looong time ago - in 1746.
3. Resistors
These resistors don't look like the ones you saw on our previous Wacky Robots.
Resistance
This is Georg Simon Ohm:
4. Transistor
The transistor is an electronic component that can be used as part of an amplifier or as a switch.
It is made of semiconductor material.
Transistors have 3 terminals: the emitter, the collector, and the base. When the emitter is connected to the negative terminal of the battery and the collector to the positive terminal, no electricity will flow in the circuit.
This is what transistors on Robby look like:
5. Vibration sensor
A vibration sensor detects changes in acceleration or vibration in its environment.
It converts mechanical vibrations into electrical signals, which the robot’s microcontroller can then process and analyze.
In Robby, both the tilt and vibration sensors are programmed to recognize when he is being shaken or moved, causing him to light up in various colors and respond to the movement.
6. Tilt sensor
A tilt sensor, also known as a tilt switch, is an electronic component that detects changes in orientation or inclination.
It works by using a small metal ball or a mercury switch that is suspended in a conductive liquid.
When the sensor is tilted or moved, the ball or mercury switch contacts two metal contacts inside the sensor, completing an electrical circuit and triggering a response.
Tilt sensors are widely used in many everyday products and gadget like in Nintendo Switch Joy-Con controllers, smartphones, fitness trackers and smartwatches, etc.
