Spencer Arduino Installation And Setup
Welcome to the Spencer Arduino setup guide!
We'll use Arduino IDE to teach you how to upload code to your Spencer, so let's get started.
Installation
After you download and install Arduino IDE, you should install the Spencer board.
Here's how to do that:
  1. Open the Arduino IDE
  2. Go to File -> Preferences -> Settings
  3. Select "None" under Compiler warnings and add the following URL under Additional board Manager:https://raw.githubusercontent.com/CircuitMess/Arduino-Packages/master/package_circuitmess.com_esp32_index.json
  4. Close the preferences by clicking OK
  5. Open the Board Manager under Tools -> Board -> Boards Manager
  6. Type 'CircuitMess' in the search bar
  7. Click the Install button on the CircuitMess ESP32 Boards package
Then go to Tools -> Board -> Circuimess ESP32 Boards, and select Spencer from the dropdown menu.
