Meet the tools
In this chapter, we'll explain what tools you'll need to assemble your Spencer.
If you have your CircuitMess Tools pack in front of you, you should be all set!
In case you got the Spencer kit without the Tools pack, this is a good time to borrow some of the tools or purchase them.
CircuitMess tools on a white background
  1. Glasses
  2. Cutter pliers
  3. Small screwdriver
  4. Soldering tip
  5. Lead-free solder
  6. Soldering stand
  7. Sponge
  8. Soldering iron
  9. USB Cable
For Spencer's assembly, any entry-level soldering iron will suffice.
White soldering iron with charging cable on a white background
Soldering sponge
Diagonal cutter pliers
Blue wire cutters on a white background
Standard cross screwdriver
Black screwdriver on a white background
