Introduction
Welcome to CircuitMess Synthia build guide!
By following this build guide, you'll learn how to assemble your digital musical sampler. With Synthia, you'll learn how microcomputers and other electronic components are used for sound production; you will be able to create unique music by playing with the pre-loaded sounds samples or recording your own sound samples with the built-in microphone, and much more.
Age group
Like it says on the box, Synthia is designed for anyone who's at least 11 years old.
You should approach some of the assembly steps carefully, so make sure to have an adult jump in if you need some help with soldering or tightening the bolts later in the process. It's okay to ask for help.
Don't worry, though! We'll go through the assembly step by step and provide some useful tips along the way. We'll give you a heads-up if there's something important to keep in mind while assembling.
Assembly time
It should take you approximately 2 hours to fully assemble your Synthia.
Skills
Learning with Synthia
As previously mentioned, Synthia will teach you a few useful things in the following few hours.
Here's what you'll learn:
  • How to solderandassembleyour very own electronic device
  • Whichelectronic componentsare needed for digital sound production
  • AboutDigital-to-Analog signal conversion
  • Whatsound wavesare, and how to synthesize them with electronic circuitry
  • How tocode custom light showsfor the built-in LED grid
  • Howdigital sound samplers work
  • How torecordand edit sound recordings
