Meet the tools
In this chapter, we'll explain what tools you'll need to assemble your Synthia.
In case you got the Synthia kit without the Tools pack, this is a good time to borrow some of the tools or purchase them.
- Glasses
- Cutter pliers
- Small screwdriver
- Soldering tip
- Lead-free solder
- Soldering stand
- Sponge
- Soldering iron
- USB Cable
This is the most important tool in a maker’s arsenal. For Synthia's assembly, any entry-level soldering iron will suffice.
Soldering sponge
Diagonal cutter pliers
Standard cross screwdriver
