Becoming a DJ
Congratulations! You have just built your own DJ mixtable!
We sincerely hope you liked the project so far because there's more coming. After doing one final check to see if everything works, you'll learn how to use its features and mix music.
Final check:
- Insert the USB-C cable into the port on the board
- Plug in the power adapter
- The screen lights up!
Insert the cable into the port
Check out Jay-D's Usage Guide!
Now that you assembled your Jay-D, click on the link below and you'll find a step-by-step guide on how to remix songs and much more.
In case you experience any trouble along the way or if the screen doesn't light up, check all the soldering connections once again and make sure you assembled every component correctly. If the issue persists, send us an email at contact@circuitmess.com with a couple of Jay-D photos attached so we can troubleshoot and help!
