Wacky logo
TRADING CARD GAME
Choose your faction, charge your bots and hack your way to domination!
resistron_2
Planck
About the Game
7+
AGES
2-4
PLAYERS
Infinity
FUN
Wacky Robots the Card Game is a card game for 2 to 4 players. The last player with robots onboard wins the game!
Control three unique Wacky Robots, each coming with an upgradable robot card, a special faction card and 5 neutral component cards with explosive side effects.
component_planck
Planck's robot card
faction_luminobots
Luminobots faction card
component_semi
Component card
During the game you will try to balance between:
•Damaging your opponent's robots or protecting your own with side effects.
•Building component combinations to upgrade and activate your robots' powerful abilities.
Setting it Up
  1. Choose 3 robots to play with and place them on the board in front of you with their basic sides up. Make sure that you have at least 1 robot with an action ability.
  2. Create your deck by adding:
    1 faction card for each robot, matching their color.
    5 component cards for each robot, with components matching the components required for upgrading said robot.
  3. Shuffle your deck and place it face down near your robots. Your play area should look like this:
discard_pile
card_back
fred_2
charlie_2
marv_2
card_back
robby_2
resistron_2
sparkly_2
discard_pile
Play area
Player Turn
Each player draws 3 cards at the beginning of the game and the youngest player goes first. On your turn you will do the following:
  1. 1Play a card from your hand by putting it in the middle of the board.
  2. 2If your hand is empty, draw 2 cards from your deck.
  3. 3Starting from the top, perform all side effects except for Shields.
  4. 4Attach the component card to any 1 of your robots by tucking the card beneath it so that only Shields and components can be seen.
  5. 5If possible, upgrade or activate a robot.
  6. 6Discard any attached component cards from your robots that you deem unnecessary.
No cards in your deck?
Shuffle your discard pile and use it as your new deck.
fred_3
Fred
Fred's robot card
Life Points
Each robot begins the game with 10 life points. You can track a robot's life points directly on its card using a common household item, such as a paper clip. If the tracker needs to go below 1, the robot is removed from the game.
Component Cards
Side effects can be found on the left of each faction and component card.
component_semi
Component card showing side effects on the left and the component in the top-right corner
Components:
CAPACITORCAPACITOR
RESISTORRESISTOR
INDUCTORINDUCTOR
SEMICONDUCTORSEMICONDUCTOR
Effects:
SHIELDSHIELD
After other side effects are performed, attach the card with a shield to a robot. When this robot is attacked you may choose to spend a shield to negate 1 point of damage. To spend a shield tuck the card further to fully conceal it. If all shields are spent on a card, discard it.
Planck spending Shields:
component_shield
component_planck
Before the attack
component_shield
component_planck
After spending a shield to negate 1 damage
component_planck
After spending the last shield to negate damage, the card is moved to the discard pile
DAMAGEDAMAGE
Select an opponent's robot as the target. The robot's owner may either spend a shield from the robot or reduce its life points by 1 for each damage dealt. All damage from 1 card targets only 1 robot.
DRAWDRAW
Draw 1 card from your deck. If this was the last card in your hand, draw 2 cards because your hand was empty, and then draw another card for this side effect.
PLAYPLAY
Play another card from your hand.
REPAIRREPAIR
Choose one of your robots and increase its life points by 1 by sliding the paper clip up the track. The clip cannot go above 10.
TAUNTTAUNT
While attached to a robot, opponents may only target that robot. Actions that deal damage to all robots are not affected by taunt. If multiple robots of the same player have taunt attached, then the opponents may choose a target between them.
BREAKBREAK
Select an opponent's robot as a target. Select a card attached to the targeted robot to discard it. You must select a robot with taunt if any has it.
BLINDBLIND
An opponent has to discard 1 card from their hand.
OPTIMISEOPTIMISE
Optimise can be used instead of any component.
Faction Cards
Wacky Robots are divided into 5 factions: Intellicorp, Luminobots, Mechanicon, Rayforge, and Synthicate.
Each faction has its own color, which matches the color on the robot cards, making it easy for kids to recognize and collect their favorites!
faction_luminobots
Luminobots card
faction_intellicorp
Intellicorp card
faction_mechanicon
Mechanicon card
faction_rayforge
RayForge card
faction_synthicate
Synthicate card
Luminobots
Luminobots are eccentric artists, excelling in creating visual spectacle utilizing complex light shows that amaze and distract.
Intellicorp
Intellicorp is an organization of robots equipped with high-quality sensors and advanced microchips that make them perfect as spies.
Mechanicon
Mechanicon is a union of worker bots who specialize in physical tasks such as moving and lifting heavy objects.
RayForge
RayForge is a guild of laser-wielding craftbots, masters of both destruction and construction.
Synthicate
Lively party makers, the Synthicate members are sound synthesizers who specialize in producing music to entertain and inspire.
Upgrading and Activating Wacky Robots Cards
After you have played your cards, you may choose to spend components from any of your robots to either upgrade or activate them. Components are spent by discarding component cards attached to the robot that contain all the required components.
upgrading_fred
Upgrading Fred
component_shield
Fred
Cards with required components are moved to the discard pile
Upgrading a Robot
After you have spent the required components, you may execute the action as detailed on the robot's card.
Activating a Robot
Meet the Wacky Robots
Some robots have actions that need to be activated by spending required components, and some robots have PASSIVE abilities that may be activated by other events in the game. Below is the list of all robots, component cards allowed in their decks and their abilities. 2+ Inductors means that the robot must have at least 2 Inductor cards in their deck.
Fred
Fred
Cards:Intellicorp
+1 Semiconductors
+1 Inductors
ACTION
Search for any card in your deck or discard pile and put it in your hand. Shuffle your discard pile and your deck together and use it as your new deck.
Dusty
Dusty
Cards:Intellicorp
+1 Semiconductors
+1 Inductors
PASSIVE
Whenever an opponent plays or attaches a card, draw 1 card for each Semiconductor component on it.
Cards:Intellicorp
+1 Capacitors
+1 Inductors
PASSIVE
Whenever an opponent plays or attaches a card, draw 1 card for each Capacitor component on it.
Planck
Planck
Cards:Luminobots
+1 Semiconductors
+1 Inductors
ACTION
Deal 1 damage to all opponent's robots.
Cards:Luminobots
+1 Semiconductors
+1 Resistors
ACTION
Deal 1 damage for each Semiconductor component on cards attached to your robots.
Cards:Luminobots
+1 Semiconductors
+1 Inductors
ACTION
Deal 2 damage to an opponent's robot, ignoring all of their shields.
Cards:Synthicate
+1 Capacitors
+1 Inductors
ACTION
Deal 1 damage for each Capacitor component on cards attached to your robots.
Cards:Synthicate
+1 Capacitors
+1 Inductors
PASSIVE
Use the action of any of your other robots.
Cards:Synthicate
+1 Capacitors
+1 Inductors
PASSIVE
When attacked: Spend any card attached to Harald to negate 1 damage.
Cards:Rayforge
+1 Capacitors
+2 Semiconductors
ACTION
Repair up to 3 hit points to any of your robots in any combination.
Example: You may repair one robot by 3, or three robots by 1, or one robot by 1 and another by 2.
Cards:Rayforge
+1 Capacitors
+1 Resistors
ACTION
Deal 3 damage to one enemy robot.
Cards:Rayforge
+2 Capacitors
+1 Semiconductors
ACTION
Deal 2 damage to one enemy robot.
Cards:Mechanicon
+1 Inductors
+1 Resistors
PASSIVE
When attacked: Spend required components to evade all damage dealt until the end of the current opponent's turn.
Charlie
Charlie
Cards:Mechanicon
+1 Inductors
+1 Resistors
PASSIVE
Once per turn. When spending components: Spend 1 component from an opponent's robot as if it were attached to one of your robots.
Cards:Mechanicon
+1 Inductors
+1 Resistors
ACTION
Double break. Discard 2 cards attached to any opponent's robots.
We offer a variety of kits. You can build robots small and big, gaming consoles, AI-powered cars, smartwatches, and much more. For full product list, visit our official store.
