Mandatory tools
The Ringo is a kit designed to educate, but it’s far from a toy.
And as such, it requires some real tools.
The equipment and tools required for the assembly are not included in the standard kit.
If you’ve bought the standard kit (no tools included) and don’t have them, now would be a good time to borrow or purchase them. The tools required are essential whenever assembling, fixing or modifying electronic devices and are the tools of the trade for every maker/hardware hacker/modder/electrician.
Many of these are available in a supermarket or a hardware store like Radio Shack, Adafruit, Sparkfun, etc…
All of the tools in the box
- Glasses
- Cutter pliers
- Small screwdriver
- Replacement soldering tips
- Lead-free solder
- Soldering stand
- Sponge
- Soldering iron
For Ringo's assembly, any entry-level soldering iron will suffice.
Soldering sponge
Diagonal cutter pliers
Standard cross screwdriver
Step 1 - plug it in
