Additional useful tools
This could make your soldering experience a little bit more enjoyable, especially when doing some more complicated projects.  Helping hand with a lot of additional tools
Multimeter
It’s a useful tool when you’re trying to figure out what went wrong with any electronics kit.  Multimeter
Solder wick
Useful for fixing solder joints when they cannot be easily reached with a solder sucker.  Solder wick
