Setup
Setup
Using the switch located on the upper right side of CircuitPet, turn it on by pushing the switch up.
Here is the photo that'll explain to you what each button and switch means.
Low battery? Let's charge your CircuitPet!
The USB-C cable is used for charging and programming your device. Insert the other end of the cable into the power adapter!
After that, connect the power adapter to a power outlet to turn on your CircuitPet.
