Batmobile
Batmobile
Now, let's check the chips and smaller components on the Batmobile's PCB.
1. ESP-WROOM-32
As mentioned previously, this microcontroller runs everything.
One of the key features of the ESP-32 is its integrated WiFi and Bluetooth capabilities, which make it an ideal platform for building IoT devices.
2. Chip CH340C
Batmobile can communicate with your computer over USB, thanks to this little guy!
3. USB port
Used for connecting your Batmobile to the charging brick or PC.
4. FPC connector for the camera
The FPC camera connector is a small-size camera module on the circuit board.
A method of connecting FPC is directly inserting it into the connector.
5. Flash memory
This is the most widely used data storage technology in consumer devices today.
Flash memory is non-volatile, meaning it doesn’t require power to store data.
Because of that feature, you are sure you won’t lose your data even if power is removed.
6. RAM (full name: random-access memory)
This is short-term memory, where the data that the processor is currently using is stored.
It is used for immediate data storage and retrieval.
Your device can access RAM much faster than any other memory, and that’s why its capacity of it is so important.
This memory gets wiped once you turn your computer off.
7. ESP32-S3
This chip is used as an additional processor that controls the camera on your Batmobile.
8. Chip TC8002
This chip is here to serve as an audio amplifier.
9. Mosfet array
This is a kind of an on/off switch for regulating LEDs.
10. Switch
Just like on the controller, this button is used for turning the device on and off.
11. Capacitor
A capacitor can absorb energy from a circuit and store it temporarily.
We call this property - capacitance. The unit of capacitance is called Farad (we use the letter F as a short for Farads).
12. Motor drivers
These drivers are used to control the movement of the motors.
